I've no experience of focuses, but I'd inspect all of the rubber pipework in that area, quite often if there is a rubber corner join that slips over one of the pipes it'll hiss if it is split (sometimes quite hard to spot). Be careful not to touch anything hot, but feel around the area for any air leaks, and gently squeeze/hold each pipe to see if the tone of the hissing changes. If you have something very light such as a piece of thin sellophane from packaging,you can also try moving that around the pipes to see any movement from air leaking.
