russ9898 said:Hi,
Looking into buying a focus ST170. anyone have one? opinions?
Also what should i look out for when viewing?
Cheers, Russ
My advice: don't get one- get a Seat Leon Cupra or an Octy vRS instead. The Leon Cupra is a superior car in pretty much every way possible IMO.russ9898 said:Hi,
Cheers, Russ
thepharcyde said:The inlet manifold which changes over at 7.5 k
Bes said:My advice: don't get one- get a Seat Leon Cupra or an Octy vRS instead. The Leon Cupra is a superior car in pretty much every way possible IMO.
wohoo said:I had one for a while, whilst they werent worth the 17-18k list price at the time, it was actually a bloody good car, handling spot one, the ride was excellent too,my only gripe was the early learning centre dashboard.
Id have it over a leon (std cupra) or a rover tbh,leons have more power but the focus is better drivers car imo.
I have had a couple of ST's from the ford range, i currently have the new Focus ST, and in all honesty i preferred the ST170, my new one is a lard bucket![]()
If was buying new now, it'd have to be a Golf GTI first,and a ST second, but second hand, you cant go wrong with the ST, but i really would consider the clio, its quite possibily one of the best hothatches ever, even better than the 205 GTI, the only problem with the Clio is that its a bit fragile.
russ9898 said:the focus handling regarded as being good then?
i was looking into a clio 172 which is regarded as having the best modern day hot hatch handling. However i already have a 1.2 clio....so concerned about not feeling the benefit of a new car. I also want a slightly larger car. With the focus being 6 speed should also be a little better cruising at speed? or is the extra gear there purely to improve acceleration?
Nor said:I looked at the ST170 a while ago, but the ZS 180 I ended up getting was better all round,
In my opinon the Leon handles the corners better too (but neither is amazing). This is just my opinion though but make sure you test drive both (and a vRS) before you buy anything!Arc said:Until you hit a corner, the Focus has far superior handling.
