Fold on 480 and 9600gso same rig?
27 Mar 2010
As per title, is it possible to fold on both a GTX 480 and a 9600GSO in the same rig?
My rig is as per my sig and i have a spare XFX 9600gso (786mb vresion) , the way the fan works is it always at %100 so i might pick up a cheap universal waterblock as the noise is really loud and have it folding 24/7.
What do you reckon it'd do, 4-5k ppd?
You should be fine, you will need to add some entries to some xml files and maybe some switches to the client to specify the core of the card with the -gpu flags
