i have created a OU on our works network called desktops and setup a policy for folder redirection if i set the option grant user exclusive rights to this admins cant access users files. Ifi i unchecked the option instead of it just allowed admins to access the files everyone can see whats in each users my documents folder what is the best way so only the user and admins can get access to the files.
i have also been told we need to switch users over to the domain login as an admin then grant domain admins rights to access all folders on the drive so then we can copy files over is there any easy way to do this
We normally map drive H:\ to \\server\home$\username but let active directory create the users folder and make sure you have owner permissions on the root folder
