hi all,
not sure if anyone has come across this problem and has a solution but thought i'd try.
i had a folder with about 200 folders within all live gigs and all are backed up onto dvd - about 200gbs total.
over the past couple of months ive been downloading more live gigs and putting it directly in this folder without backup. i now want to back up that stuff only to format the drive but dont know if its possible since i dont know whats backed up already and what isnt.
aside from burning another 50 duplicate dvds - i.e. burning everything again - is there anything anyone can think of that can sort the new unbacked up stuff against the older (already on dvd stuff) - even if it means i have to insert the 50 dvds in the process.
any advice appreciated,
thanks
thanks
