Folder sychronisation
5 Apr 2004
Bloxham
I have a laptop and a media PC, both running Windows 7 Ultimate. I have folders on both machines for Music, Films, Pictures etc.
I download music, video, pics etc to my laptop first, then copy it to the same named folder on the PC if/when required over my home network as the folders are all shared and open to read/edit.
I'm frequently buying music though and adding albums to artist folders and it's a pain to keep pushing it all manually to the media PC. Is there a way I can sync the folders, so anything I add the laptop Music folder will also magically appear in the PC music folder? I've had a Google around and confused myself more if anything...
create a batch file using the robocopy command and you can sync from your laptop to what ever other devices you want
robocopy sourcefolder \\destfolder /MIR
open dos window and type
robocopy /?
for more info
my example
SET SOURCE=F:\store\music
SET DEST1=\\nas\music
robocopy %SOURCE% %DEST1% /MIR
Thanks Lurkio, I have next to no idea what any of that means though I'm afraid!
Is there not something built into Windows that makes it simpler? I know you could sync folders in XP and probably before, I've never played with it and don't want to go in blind.
Synctoy 2.1 is from MS, it'd do this but won't sync automatically without you making it a scheduled task etc. But has a reasonably good GUI and is easy to use.
I tend to use fastcopy to sync my folders but I don't mind doing so manually as I want that extra control over it (lost too much in the past). Right click - fastcopy, set details and off it goes.
If it's all going on the laptop first and then getting copied to the PC, let me know the EXACT folder names and I'll write a robocopy file for you. It will just be a case of double clicking the file and it will copy all new/updated files
IE..
C:\user\Chris\Photos
C:\user\ChrisPC2\Photos
I don't mind manually asking it to sync, I can just do so every week or something when I've made updates to the folder on my laptop.
I'll give Synctoy a go on a test folder and see how I get on.
Cheers fellas :)
