folder taking ages to load
14 Dec 2005
the first time (after starting the pc) I go to look in my downloads folder it takes about 30 seconds to load or whatever it's doing (the address bar fills up with green)
all I want to do is be able to sort the files by date or whatever to look through them, but I can't until the green bar has filled up
I can search for things straight away but sometimes i need to look through things by date/name or whatever
surely it shouldn't take so long just to load a folder
Make sure hidden files and folders is ticked in Folder Options (type it in the Start/Search box), copy anything you need out of the Download folder to somewhere safe and then nuke the contents
I had this problem with a corrupt .gif extension registry in the past. Might be worth moving the different file types in to separate folders to see if something like that might be causing the loading issue. If every folder bar one loads smoothly you've found your culprit.
