There's a wealth of advice on p67 motherboards and Sandybridge cpu in the relevant hardware sections, but i would rather get a prospective from someone that has/will be using it in the folding/crunching arena and what there particular thoughts are.
Been wanting to upgrade from x58 for a while, as a novice overclocker i found it way to confusing, i have put hours of patience into achieving a good solid overclock not very successfull i have to admit.
So the general consensus the way i see it is an i5 2500k or i7 2600k cpu should be relatively easy to get and maintain a solid 4.5Ghz overclock non?
I read a lot of forum posts and threads eventually decided on a gigabyte ud4-b3. Given that i like my power would i really see an improvement from the 2500k to 2600k i know the latter will give me 4 extra processing threads which would come in handy but an extra £80 hmmmm just not sure.
Now given that your all power mad and believe in wringing the last drop of performance from your hardware
what would you do? Am aware of the voltage requirements so its memory shopping today, any thoughts or advice on what might be best please chip in. Would like to get remainder of system ordered over the weekend for a wednesday setup.
Be happy to hear your comments/criticism/input but please keep the "nutter" comments to a minmum
Thanks peeps much appreciated in advance
what would you do? Am aware of the voltage requirements so its memory shopping today, any thoughts or advice on what might be best please chip in. Would like to get remainder of system ordered over the weekend for a wednesday setup.Be happy to hear your comments/criticism/input but please keep the "nutter" comments to a minmum
then i will split the use between bigadv and gpu crunching on seti. Besides i would get sent to coventry if i were to use 2 580 for folding - be ran out of the country more like
