Hi all,
I am after some help / advice.
I have been a folder for arround two months now, have set up my own team (168648) and in 8k ranks. I am going to put all of my Folders on the same name and join your team.
My questions, What is the best way to fold on my rigs? What Clients do you reccomend i use?
Gaming Rig:
Intel QX6850 (quad extreme 775) @3.64
4gb OCZ Flex @ 1332mhz
Sli (x2) 9800GTX Ultras
Asus Striker Extreme Gamer
Veloc Raptor 300gb hdd
4x 1500GB HDD’s
BeQuiet 1200w PSU
Fully Watercooled
64bit vista ultimate / Win 7
Media PC:
AMD Pheneom 9650 @2.37 Quad
8gb 1200mhz(i think) Ram
8400GS (heatpipe)
Asus board (used as HTPC, not too sure what i put in at the mo)
2x 500gb HDD’s
Stock Cooling (Antec Fusion case)
My Server:
Intel Core2Duo E7200 @ 2.53 OR E8400 (i have a spare E8400)
2.5GB DDR800 Ram
Asus P5Q Deluxe
9400GT Heatpipe
64Bit Vista / Server 2008
5x 2000GB HDD
Spare PC:
AMD FX55
2gb Ram
Dfi LanParty Expert SLI
7800GTX 512mb
1x 500gb HDD
64Bit Vista / XP Pro 32bit
Dads PC:
AMD Phenom 9550 @ 2.48 Quad
4GB DDR800 Ram
Asus M2N-SE2
8400GS
1x 500gb HDD
XP Pro
I have VMWare on All pcs. If it makes any diff.
I also have a handfull of high spec laptops (i dont fold on them at the moment but given the OK i shall start)
At the minute i have the Windows Tray Client installed and running as a service.
Many Many thanks
Martin
Gaming Rig:
4x 1500GB HDD’s
BeQuiet 1200w PSU
Fully Watercooled
Media PC:
8400GS (heatpipe)
2x 500gb HDD’s
My Server:
2.5GB DDR800 Ram
Asus P5Q Deluxe
9400GT Heatpipe
5x 2000GB HDD
Spare PC:
AMD FX55
2gb Ram
7800GTX 512mb
1x 500gb HDD
Dads PC:
4GB DDR800 Ram
Asus M2N-SE2
8400GS
1x 500gb HDD
XP Pro
Many Many thanks
Martin
This one would probably return more than the others combined if you got both cards and the Q running well.
