Folding@Home and GPU
13 Jul 2012
Hiya, sorry if this isn't the right section but I'm running the latest FAH client on my windows HDD. I noticed that it seems to be processing two jobs at the same time, although one seems to take less time than the other. Am I right in assuming that the client by default is using my GPU (GTX 670) as well as my CPU? The reason that I suspect it to be doing both with the one client is because I also have FAH on my OS X partition and the client on that OS only does one job at a time (GPU Folding isn't supported on OS X).
I have the CUDA driver installed as I thought it may help if the program is indeed using my GPU, it's just I thought there was a different client for GPU folding.
Thanks!
There is a distributed computing sub forum here mate, you might have better luck in there. Go to the main page and scroll down. Its near the bottom.
