Folding power ↓ on idle - solved
25 Dec 2008
Sheffield/Norwich
Hi all,
Just posting a thread about an issue I had which is now resolved, in case anyone comes across the same problem.
I recently noticed my frame times dropping on SMP2 client, Windows 7, on idle by about a third. So I figured something else was using the processor, and found out it was a svchost.exe. Anyway, turns out the svchost priority is set to Low, so it's hopefully a very simple matter of upping the SMP2 priority from Idle to Low, but possibly needs it setting up to Below Normal - will find that out in the next few hours probably.
Anyway not very exciting but I thought I'd post.
UPDATE: Upping the SMP2 priority did not help. I have now set up a batch file to up its priority to "below normal" in Task Manager and will find out tomorrow morning if this has done the trick.
UPDATE: Below normal priority seemed insufficient. I've now upped it to above normal when the computer is idling and below normal when the computer is in use, job done. :)
Shouldn't really have an svchost using CPU constantly! You should be able to use Process Explorer to find out which service is doing it.
Yep, I know. Could be related to GTA IV recently being installed, not really sure. Anyway I'm too lazy to figure out the problem now I've figured out how to stop it impacting folding :)
If you're interested, the services I think that could be involved are called 'Power', 'PlugPlay', 'DcomLaunch'. Not sure what the last one is, it shouldn't be either of the other two I wouldn't have thought.. but, like I said, can't be bothered :)
