- 5 Aug 2003
- Lazytown
Morning all, Parp parp to Vent & Gazzza, only a few days left then its new cell time.
Babyface UK
Babyface UK
happytechie said:shocking behaviour, handbags at dawn will be the only way to settle this![]()
VeNT said:DAMN YOUR EYES!!!
just you wait! I've got two core duo systems with x1900XTs in the pipline!
your time draws neer!
VeNT said:beware!
I just borged a P4 3ghz with HT,
its a 24/7 (nearly) so should make me some nice new WUs!
also its getting 1gig OCz dual chan sometime this week, do you need to re-install FAH after upgrading the ram?
you might want to just re-run the config to make sure it's set to use all the RAM (or as much as you want it to) rather than the old limitVeNT said:also its getting 1gig OCz dual chan sometime this week, do you need to re-install FAH after upgrading the ram?
hehe, I'm installing it as soon as it arrives, so I'll update it then!rich99million said:you might want to just re-run the config to make sure it's set to use all the RAM (or as much as you want it to) rather than the old limit
