Follow on from 5600G / 5700G
16 Aug 2017
ZZ9 Plural Z Alpha
Any idea if we are likely to see follow on products for the 5600G / 5700G 65W devices using Zen 4 cores and DD5 ?
I could make good use of something like an ASRock DeskMini with a higher performance CPU !
They're making them for laptops, so it's likely to come (but they're often slow with releasing them for DIY), though if you're not gaming, the Zen 4 IGP may already be sufficient.
Got an upgrade itch last night with my Ryzen 2400G powered HTPC, but after seeing some comparisons to the 5600/5700G - there didn't seem to be that much of a difference in gaming.
My HTPC has space for a GPU but it would require some serious cable management, and it's primarily used as a media server but a low end backup gaming system would be good.
Surprised my Gigabyte AB350N-GAMING WIFI AMD B350 in there supports 5000 series CPUs, it cost £90 lol.
They have always seemed late to the game with them … which i think is a shame. I’ve long wondered why we dont see APU’s but with a bit more video encoding/decoding power built in for simple video editing.
