Font size on OCUK forum suddenly shrunk please help!
9 Dec 2009
Bristol
Desktop res is 1920 x 1080 which hasn't changed, I'm using Chrome and all my other tabbed sited have the same size but OCUK has tiny writing - I can barely see it.
Please advise what I have pressed to casue this or what I need to do to sort it out, I need need my daily OCUK forum fix!
you've probably turned yoru font size down within IE / Other browser.
Hold ctrl and roll your mouse wheel or - or select the relevant menu and click normal.
Failing that, you've zoomed out - check bottom right.
You don't want to mess about with Ctrl+Mousewheel or Alt+F4 too much it'll cause all sorts of problems with your browser.
its actually happened to me also :o
and no, ive not shrunk the font, i have 2 ocuk forums windows open, an old one from my build log i was going to update, and a new one im currently browsing.
the new one has small font, the old one doesnt :/
It appears either zero works actually, always thought it was only the numpad one :p
GO AWAY DONS
(I did fall for that)
