Fonts help
Caporegime
28 Jan 2003
England
Hi,
Could someone using Windows 7 (I'm on RC1 if it makes a difference) please send me the below fonts.
I have lost mine. :(
ARIALN.TTF arialbd.ttf lucon.ttf tahoma.ttf trebuc.ttf
arial.ttf cour.ttf marlett.ttf times.ttf verdana.ttf
Because the Marlett font is necessary for rendering buttons (arrows, checkboxes, etc.) properly for Windows it's set as a hidden file in your Fonts folder for safety.
If you want to see the Marlett font (and other hidden files):
1. Go to View | Folder Options...
2. Select the View tab
3. Find Hidden Files in the Advanced settings list
4. Select Show All Files
5. Click OK
Marlett should now show up in your Fonts folder. Just remember not to delete it! :D
