Foobar annoying me!! Please help.
12 Sep 2003
Newcastle, UK
I'm trying to change the appearance to this:-
http://www.hydrogenaudio.org/forums/index.php?showtopic=58889
I've re-installed Foobar to start from fresh and downloaded all the components listed for it to work. I have also downloaded the fonts. However, when I launch Foobar and try to change the appearance under Panel UI from Default.pui to iFoo.pui it won't work. I click "save all" and it jumps back to default.pui in the list. :confused:
So basically my Foobar player is just a white box? Why can't I get it to look like the one on the forum? :( :( :(
Thanks for any help.
Mint. Got it working.
Downloaded the beta Panel_UI and then re-installed the .pui with Foobar closed. Looks ace! :D
