foobar2000 users
25 Oct 2002
I've just switched from xp to vista64 and installed foobar2000 with the fofr config. I know some of you use this.
http://www.fooblog2000.com/2007-06/fofr-version-09
Problem with this is that there are no play controls in the config: play, pause, track seek position, volume etc.
Anyone else have the same issue and know how to add it or use any other decent config that has an explorer menu?
edit - after a lot of messing around, managed to get it working on an older version of foobar.
