For a quiet life
15 May 2006
B'ham
hi, about to build a pc and wanting it as silent as possible. so what would make the noise in my pc?
what cpu cooler (intel LGA775) would be the quietest? and sata2 hard drive?
i assume those would be the main culprits but any other suggestions would be great.
Stock graphics card coolers are noisy, change it for an aftermarket one or have a fanless card installed :)
Graphics - Thermalright HR-03 fitted with the 92mm fan of your choice
CPU - Ninja with a 120mm scythe S-flex 800rpm or similar
HD - Samsung Spinpoint S-ata 2 in an enclosure
you could get a passive gfx card, passive psu, a sythe ninja running passive on a lower end c2d cpu, shove that all in a p180 and you'd struggle to hear it tbh.
weescott said:
A case with 120mm fans.
Passive PSU
Nope and Nope. Vast majority of 120mm case fans are very noisy. No need for a passive psu, a seasonic or corsair will be silent from 30cm anyway but a lot cheaper and will last a lot longer.
Scythe s-flex fans all click, no good for a true silence enthusiast.
Get a nexus 92mm fan if you're getting one, these are the quietest 92mm fans there are.
You need to go and have a good read of a few articles over at Silent PC Review.
Sources of noise vary, but i'd say what you need is a board with passive chipset cooling, a Thermalright ultra 120 with a nexus 120mm fan, a Nexus Drive-A-Way silent enclosure for your harddisk, you can put almost any disk in that and it will be silent. You need either a graphics card with a silent cooler such as the power colour X1950pros or the Galaxy 7950 gt with zalman cooler, or an after market cooler. Get a seasonic or corsair psu and a good case such as the p180 and you should have a near silent pc.
hdd: Samsung/Seagate hard drives
case fans: nexus 120mm fans
case: lian-li case without a side window
g70
v1/2000+
pc -767
v1/2100+
imo, are all awesome
cpu: tuniq tower for the cpu, the fan on the lowest setting on the dial is inaudible
mobo: don't get a motherboard with fans all over the place, asus do heatpipe mobos that work well with air cooling.
gpu: ive heard good things about ati's x1950xt cooler, the 8800 cooler is inaudible.
arctic cooling x1/2 are also super quiet
psu: seasonic
if you get an asus mobo, hook all the fans up to the mobo and enable ai quiet
