For everyone who likes it BIG!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
The new BeQuiet Pro Cooler has landed.
Hows it compare with the DH14? Size wise that is, as the Noctua is the biggest one I've ever seen.
noctua size 158 x 140 x 160mm ( L x W x H) bequiet pro Dimensions: 133 x 150 x 166 (L x W x H)
so the be quiet is shorter but slightly wider and taller
how is the cooling is it as good or better than DH14:confused:
need to know how well it does the job before i rip the heart out of my puter and spend £64 on another lump of metal that might not cut it :mad:
looks alone won't help squeeze out a few more Mhz :eek:
They should bring back those plastic tabs the HS/F clip onto, just for a laugh :D
But damn that is a big cooler. Wonder what the clearances will be when matched up with some of the taller Ram modules/motherboards.
