For those running a Windows Mobile 5.0 device..
18 Oct 2002
What version update pack (AKU - Adaptation Kit Update) is installed on the OS?
To find out: Start>Settings>System>About> Look at the digits following the Build Number.
My Vario II states 2.3.0.
Reason I ask is AKU version 3.0 introduces the following:
WPA2 WiFi support (big thing for me as my home network is WPA2)
Ability to navigate Pocket PC’s folders containing messages without drawing the stylus (quite handy)
Other features introduced can be found towards the bottom of this page: http://www.mobile-review.com/pda/articles/wm-aku-en.shtml
I'm actually not 100% if the AKU 3.0 is still a few months away from release or not. :confused: Anybody know anymore info?
My Vario II is 2.3.0 as well - standard build for T-Mobile, I guess. Need to hear from an Orange m3100 user
I can already do this - press the Menu soft key whilst in your inbox and navigate using the d-pad or thumbwheel to 'Go To' where you have the "Folders" option
