Forced Depth
20 Feb 2007
Hi chaps.
Just wondered if there is a way to force a single application to change windows color depth to 16bit while its open, then change back to 32bit when the application is terminated?
It's just the application only runs in 16bit depth, and its a pain in the back side changing it back and forth every time i want to use it.
Thanks a lot for any help!
Frosty
"BUMP"
Maybe there isnt a way. But its worth a BUMP to see if any of you who didnt catch it before have any idea how to do this...
Thanks again
Frost
Might be possible if you're using an NVidia card and use the NVidia control panel settings (which can run separate graphics card settings per application) but that is a big might.
