Forceware 162.15 Beta
18 Oct 2002
Mars
Vista 32/64 XP/2000
Beta driver release.
This driver supports single GPU and NVIDIA SLI™ on DirectX 9, DirectX 10, and OpenGL.
Improved compatibility for Lost Planet
Added “Resize the HDTV desktop” underscan compensation option
Added support for Digital Vibrance Control on GeForce 8 series GPUs.
Numerous game and application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
Digital Vibrance definatly working here,
Profile settings now saving correctly in Vista, where before i had to edit the XML files to allow all access
So far so good
Installed no problems, using digital vibrancy with no problems, and Lost Planet saw an increase in fps by maybe 10fps, not too bad :)
DV at last
Who's doing benchies? :)
yeah, these are the best set to date, feature working wise (vista x64)
Im at XP performance levels now, as i expect most of you are too
Wonder if Sli users will have any luck with this set
They break Company of heroes in DX10 mode totally !
First it runs in windowed mode then crashes to desktop with an .exe error when the loading of the benchmark is complete :mad:
ffallic said:
Anyone else lost all their game 3d settings? The entire list is simply gone for me!
Mine are all here,
I just installed over the top of the old drivers
Ive only got Call Of Juarez to Test DX10 and it ran through ok, will see if anyone else reports problems with COH
Got a benchmark in COH by turning the settings down
Av 30.2
Max 60.1
Min 11.2
All Highs, 8xAA no ultra settings
Still in windowed mode though which may be making it worse than it is.
Cant fix that
