Forceware 171.23 WHQL for XP
Just tried to install these and I'm getting loads of errors saying various different files can't be found :mad: This happening to anyone else?
I'll try the 171.23 Betas and see what happens.
EDIT: The betas from Guru3D worked fine, not sure what's up with the other ones. Only tested Crysis so far - FPS went up from 32.68 with the 168.28 Betas to 33.12 with the 171.23 Betas. Woo hoo :D
I'm trying UT3 now - it was crashing incredibly frequently with the old drivers so if the new ones are any more stable they'll be a worthwhile upgrade.
EDIT 2: UT3 is definitely more stable - it still crashed twice on me, but it would normally have crashed about 6 times in that time. 171.23s seem like a decent set of drivers.
