Forceware 174.16 WHQL Candidate XP 32bit
With the mirrors and your inf file :(
Got "copy error" nvdispsr.dll is missing???
Odd. :confused:
Did you run the Setup.exe after extracting to install (near the bottom, which is the one you need to run), or did you run the one you extracted called 174.16_geforce_winxp_32bit_international.exe (which isn't the one you run).:)
So you cant just drag my modded.inf over to where the extracted files are, and say yes to replace when it asks (like open both windows (one with my.inf), and the other window with the extracted drivers in), then just drag my .inf across, and say yes to replace, then run setup.exe.:confused:
the one from mirror was english not international
Doh
international installed fine, gonna restart and run crysis benchmark (41.6 to beat. :D)
Ofcause i am , its not that difficult to do :p
Might be related to the mirrors being US 32mb and your inf file used for the international 74MB... i used the mirrors , who knows.
Will try the main international instead though the link was crap slow earlier
Doh
Ahh, didn't know it would only work with the international version my .inf, glad you got it sorted. :)
Updated first post. :p
DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 43.635
got me extra 2.035 fps in crysis, shame i only have the demo for benchmark and dont play it :D
I seriously need a mirror for the international version and the modded inf , can't get this off the main nvidia site :(
Test drive unlimited looked fine so did oblivion and flight simulator X (demo) however 3dmark06 scored almost 300 points less (11972 compared to my 12241 before)
Think it might be rollback time as well :S
