Forceware 174.16 WHQL Candidate XP 32bit
installed and tested on crysis:
Up by 1 or 2 FPS
Also, no more BSODs for me so far in crysis.. played thru whole first level with no problems, no texture flickering or anything, at least nothing noticable! Keeping these drivers
These are running fine for me - cheers :p
Can anyone explain Nvidia's numbering scheme? Just had a look on their beta site and there are two drivers listed
Name Version Release Date ForceWare Release 169 WHQL
169.25 December 20, 2007
ForceWare Release 163 WHQL 163.75 November 6, 2007
and these modded drivers are 174 series, can someone who knows what is going on explain the reasoning behind the different number schemes and what they mean???
That is of course if there is a meaning behind it..
Some better fps with these drivers than the ones i was running from the nvidia site.
3dmark06 - increase of 56 (14690 - 14746)
crysis - +3.9fps avg (43.0 to 46.9)
css fps also seems to sit a little higher than it did on the last drivers which was nice.
every little helps ey. ill be sticking with these.
I hope I get 3fps increase, that should give me nearly 50fps in Crysis, I tell ya every driver release that has worked so far has given good improvements, seems like the GT is always getting slightly faster. Ok 1fps aint much good but for Crysis benchmark its always good :D.
