LukeManUK said:
Dutch Guy said:What does the 9x.xx indicate, does that mean that there are a lot of changes that they went for a 9x.xx instead of 8x.xx![]()
Where would I find that?wellibob said:If you install the new ntune 5...
Bony Maloney said:Where is the overclocking option in the new control panel after installing coolbits?
It appears to be working from the "old" control panel with these new drivers.Tim said:Assuming coolbits is compatible with 90.xx?
I also need to lock my refresh rate![]()
wellibob said:Dunno if i like the new drivers or not. TV out feature is a bit long winded, but the new features for clarity and edge filtering are good. If you install the new ntune 5 , you`ll find all your sliders, and clocking abilities are listed for mobo, gpu etc etc, including voltage controls![]()
I don't think so mate, all the voltage options I'm getting are displayed as N/A so it must be motherboard or gpu specific.Johanson said:Voltage controls? Does that mean i can change the voltages on my 7900gt without the volt mod?
