ForceWare Release 158.45 Beta
18 Oct 2002
Mars
Version: 158.45
Release Date: May 31, 2007
Beta Driver
32bit
http://www.nvidia.com/object/winvista_x86_158.45.html
64bit
http://www.nvidia.com/object/winvista_x64_158.45.html
Release Highlights:
Improved performance for DirectX 10 version of Company of Heroes
Improved 3D performance for single GPU and NVIDIA SLI
Numerous game and application compatibility fixes
This driver supports the following 3D features:
Single GPU support
DirectX 9 support for GeForce 8 series GPUs
DirectX 10 support for GeForce 8 series GPUs
OpenGL support for GeForce 8 series GPUs
NVIDIA SLI support
Just thought id share it.
Ive noticed quite a difference, pretty much same speed as XP now. My FPS in Lost planet DX10 are now slightly better than DX9 in XP.
3DM06 at stock now returns 7530 compared to 7871 in XP
Seems to have killed my overclock tho. When i set the cards to a clock that i know the cards can do i get artifacting :confused:
Great at stock tho
On Vista ultimate 32bit
hmmm I can't seem to get Aero working with dual monitors enabled?
Just ran 3DM06, up by about 50-100 points from the WHQL ones
Down about 100 marks in 3dmark06 for me, 11265
Had 11375 with 158.18 WHQL
Going to go back to 158.18 - 2nd May 07
Edit -
Lost Planet DX10 - No V-Sync - BFG 8800 GTX 645/1050
All Settings high except "Shadow Quality" - Medium
4x AA
8x AF
1360 x 760 x 64bit
158.45 Drivers :-. . . . . . .158.18 Drivers
Snow = 62 Average FPS. . . . 57 FPS
Cave = 51 Average FPS . . . . 53 FPS
Seems a little bit better than I remember.
Well ive fixed the overclock isue. Now running as per my sig.
I get 8746 in 06 compard to the result in my sig for XP
However games seem a lot better :)
