forcing analog output on a 7800?
i mean have the drivers force an analog output through the analog pins on a dvi-i cable, its complicated but im trying to get my monitor to run in analog mode not digital,
Well if you don't do it the software way and do it via cable instead, you can get a DVI-A to DVI-A cable for peanuts, but you probably already know that :).
I can't say where even though they couldn't really be a competitor to OCUK if they tried and only a few bits vaguely in the same market, aimed at businesses though but I did a google search, selecting the uk and it was one of the very first at £4.27. I can't really give you any more help than that as they are around :). No idea on the software bit tho, I would go the hardware route myself is all as then it physically has no choice ;). At least you have it as an option to try.
