Trying to help a mate out, his engine sounded like a bag of nails, so I said coil pack, as it turned out one of the plugs on existing had clearly had some sort of moisture damage as it was clearly corroded so put a brand new ford item on.
Started up fine thought it was fixed but just rung him, only to be told as soon as it warmed up it is running like a bag of nails again.
I can only really think of two other things as he sais engine management light is just flickering now instead of permanently on.
These would be either throttle position sensor or faulty injector any other possibles have put on my diagnostics first of all and got error codes p0302 and p0400 these are both pointing to a misfiring cylinder which I already know.
Thanks for any help, I am pretty competent myself but don't hurt to ask on here in case it am missing something.
Hmm just thought could it be the MAF
