Ford Fiesta Bluetooth commands
13 Jan 2003
Belfast
Hi guys,
Does anyone know where I can find a list of commands for the bluetooth controls in my 2008 Fiesta Zetec? The manual is pretty much useless and I only just discovered through a google search how to store phone numbers into it after having the car 9 months! I thought it was something to do with my phone!
Thanks
Matt
The manual for the MK7 lists loads? If it's 2008 does that make it a MK6 or MK7?
The MK7 manual is here and page 173 onwards lists lots of them.
If it's anything like the Mondeo I owned there is a help command that says how to use the system. The system wasn't that great though and quite limited in functionality.
Have you tried saying "help"?
I'm sure my civic has a seperate manual with a list of the menus and commands you can give - Saying "help" also gives a bit of, well help too.
Not sure how the ford system is but in the Honda the voice command is completely useless, it doesn't understand anything I say if it's longer than two words really :rolleyes:
If you have a southern English accent you may have better luck I guess!
There is a lot of things you can do that aren't listed in the manual.
I call people by saying "Call...<Name>". I couldn't find that in the manual.
I wish it was a bit more clever and was possible to implement Siri in it.
