Ford Galaxy Windscreen?
17 Jun 2004
Eastbourne , East Sussex.
Heya all - am struggling to find a windscreen for my car - its a 2012 Ford Galaxy, with all options (well except keyless).
Thje windscreen needs changing - but non of the windscreen fitters can find it! The part number is
1821611​
instead of the part number how about spec of vehicle, having been in the trade i find it hard that a 2012 galaxy windscreen is hard to find .) what is it about the screen making it so hard to get?
have you tried the national companies? the only reason i can see is if someone had a one off top tinted windscreen fitted at some stage (they were always special order)
if it truelly is a problem i suggest giving
www.tynesidesafetyglass.com
Tyneside Safety Glass
they make windscreens including odd ball specs etc
The problem is that spec ; it has heated screen, IR and acoustic glass, rain sensor and lane depart camera. Its the lane depart camera which makes it hard to find . National windscreens and autoglass have both said unavailable.
You contacted Ford themselves? They'll likely be as much help as a knitted jonny but persistence often pays off.
Called Ford. They can get one, its in Germany ! woohoo, insurance won't cover it as it's £1678 +vat and fitting, which would be over 50% of their valuation of the vehicle
