Hi,
A pheasant took out the driver side wing mirror on my 2010 Ford Fiesta Zetec and I need a full new unit fitting. Knowing virtually 0 about cars - is this a sensible thing to try and DIY or should I take it in?
I think this is the correct part, manual fold with indicator? https://www.wingmirrorman.co.uk/win...-mirror-electric-heated-matt-black-right-side it's matt rather than painted but if I go for a primed one I have no idea how I'll get it painted to match the blue/cyan body?
This is what it looks like:
Inside door fitting hole?
Good side
Broken side
In terms of fitting it, on the inside of the door behind the mirror, I can locate one nut/bolt shown above - is it a good assumption I can just undo this and fit the new one? Or is there likely to be more complex door disassembly required for the electrics?
Also - I do need to make a 2 hour drive home after Christmas before I can fix this. Is that legal with a broken driver side mirror?
Thanks very much for any help!
Good side
Broken side
It looks like you have to take the door apart to connect the electrics but hopefully that won't be too hard...
