forever loosing connection on bf2142
12 Feb 2006
Surrey
just fired up bf2142 after a few weeks of not playing it and all that seems to happen is i loose my connection to the server and get chucked out of the game. this happened to me before, more so on some nights buts its a complete nightmare i cannot play the game at all. it will either load the game, play it for a few moments then chuck me out, or not even allow me to play saying connectin lost.
wondering if anyone else has or have had this problem befreo?
do you think it could be something else other then the game like my interent? i have really good speed broadband thats on a router with around 10 or so pcs, though none are doing anything atm other then just being on.
Do you have a USB modem? Who is your ISP?
Go to www.evenbalance.com and get pbupdate. Updates the necessary punkbuster files but that will only be a problem if it says you were disconnected my pb
Have you googled it. If you have a certon security patch applied, then you will need this patch.
WindowsXP-KB924867-x86-ENU
Google is your friend.
It sorted my disconections.
