What if you have this at your disposal?10 char. password comprised of only letters will take around 172 days to crack using brute force, make yourself comfortable.
What if you have this at your disposal?![]()
They don't use them because of the crappy RSX GPU. They use them because of the power/performance ratio of the Cell CPU's.This is why GPUs are far better and why the US military has a cluster of Playstation 3 consoles crunching away
I know they make something for zip files, I just cant find it.
