I am having a problem with a form I made in rails it works fine on a computer.
But on a ipad you can click on the first row of cells and you can click in them and the keyboard comes up and you can enter data, if you click on the second row the keyboard disappears and you cant get into the fields. However if your on the first row then you can use the up and down arrow on the keyboard to move between fields.
Here is a codepen of the generated code http://codepen.io/anon/pen/reJoeX I cant show you the proper code as its behind a log in.
On the site after the handicap field the next set of player data starts on a new line.
Is there anything I am missing?
Cheers
Cheers
