Format FAT32 Partition larger than 32gb
14 Apr 2006
Scotland - North Ayrshire
Can anyone point me in the direction of a peice of software I can use with windows XP that will allow me to format a FAT32 partition larger than 32Gb.
Thanks
I have a 200Gb 2.5" drive in a USB caddy that i want to be able to plug straight into things like my ps3/xbox/TV to play films from it directly and thoses devices will only read the partition if it is FAT32.
I could go down the line of creating multiple partitions of 32gb each but this is no good as the TV will only read the last partition created not display all of them.
I'll check that out, if anybody has any recommendations for tried and tested software that would be appreciated as well.
I've always used fat32format for this - unzip the executable somewhere in your %path% (eg C:\Windows or C:\Windows\system32), then open a command prompt (as administrator) and it's just "fat32format x:" (where x is the drive letter). :)
OK - I'll bite.
Why do you need to create large FAT32 partitions?
You really shouldn't be using those these days.
Quite common for PS3 usage.
OP you can do it from a live linux cd such as Gparted, suprised this hasn't been mentioned already.
The 32GB limit is a Windows formatting limitation, it will read and write to a larger FAT32 partition, but it wont format one.
