Format SSD while still in system?
1 Dec 2011
SW3
I have just sold my 3 SSD drives that i have, the only problem being i don't know how to fully wipe them clean while they are in my system, will a quick format do the job?
I don't want to install anything on them and i don't have access to an external drive caddy.
2 are freshly formatted but my main drive is running Windows 7.
Any tips much appreciated.
SSD needs secure wiped to get back to near factory performance.
A Full Format like a Mech-HDD would be a very wasteful full write off the SSD's life.
How can you format a drive you are using it for anything never mind Windows?
Do you realise what you just asked?
Yes i know it's not simple :p I think the easiest way to do it is put the windows disc back in, choose the install option and format the drives while in the menu and then shut the system down?
Without an external drive caddy i can't wipe the drive.
equally, have you looked on your ssd vendors site ?
there seems to be a specific samsung utility, that I would use on the Evo ssd I have.
https://www.pugetsystems.com/labs/support-software/Samsung-Secure-Erase-949/
which, it says, creates a bootable usb.
You make it sound as though you want to clean your disk that is running windows on your active system - a bootable usb should do it.
(are you really selling the complete system, or you have a new ssd lined up for the OS ?)
