- 6 Mar 2007
I set my primary boot drive to my DVDR where my Windows XP disc is. It doesn't load, I've tried disabling all other ways of booting etc with no luck.
I can load into my existing Windows and load the disk there and do an install, when the PC restarts it loads the disc and I can format/partition there.
However due to having only 1 partition I can't format it or partition it because the Windows install files are there.
I also can't format while in Windows through Cmd prompt as I'm active on the current partition.
So how do I do it?
I have no floppy drive and it's Windows XP Home.
So how do I do it?
