Formatting HD Fat32
19 Jan 2005
Romford, Essex
I need to format an Ext HD Fat32 so that I can play vob files from a USB port mounted on the front of my DVD player.
I am led to beleive that there is a max size that I can either use or format Fat32. Can anyone tell me the largest partition I can format that size, is it only a windows issue and is there another way round the problem. Thanks
It's only an issue with the Windows in-built partition and format.
Use something like PartedMagic or any number of partition managers and you can use whatever size you like.
