fortress forever not working with samsung LE32R87BD
Right click Fortress Forever in Steam then click Properties, click Set Launch Options then type:
-width 1024 -height 768
Replace the numbers with a resolution that your monitor supports. After you've got in game and set your video options to how you want it make sure you remove this afterwards to stop it resetting your resolution each time you run it.
should have a config file in the games steam folder which will have the resolution etc saved in it too, change it to something thats compatible with monitor.
