- 2 Jan 2012
- UK.
Hey guys, my sig got removed earlier, it's 399 x 74 is that size ok? Thought it had to be under 400..
Sig rules....
A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels.
Dimensions are ok but the size is not. Yours is 49.2K so it will be removed again.![]()
Ah ok, I did wander why it got removed.. I'll shrink it or summin...
