Guys,
I've done a quick search but found nothing of use. I need some software to make a discussion forum, just like this one. Now, I'm not very ofay with PHP or MySQL. Are there any packages out there that are fairly easy to set up and customise with colour schemes etc?
What Forum Software do *you* use?
Also, for the Admins/Mods.
How easy do you find vBulliten to use from an Administrative POV. Is it easy to use? If you wouldn't mind, would you please take a screen shot of some of the configuration pages? I'd try myself, but I'm travelling overseas at the moment and only have my laptop.
Basically, I'm after the pros and cons of the Forum software that you guys use - from all aspect - for a work project.
Many thanks in advance,
Greg
Greg
