I am in the early stages of purchasing a property which is currently identified as being at high risk of surface water flooding on the future flood risk map on the Gov Environment website. There are no rivers or seas in close proximity, and I understand that flood risk assessments are generally based on geographic and topographic data rather than the physical condition of the land (e.g., whether it is concreted or grassed).
The current owners have installed a full shingle driveway, ACO drains at the front of the property that drain into the main sewer, and a block lip at the top of the drive. They have confirmed that, in their seven years of ownership, they have not experienced any surface water flooding issues, even before these modifications were made.
I posted on the local community group, and someone two doors down responded with: “they used to get surface water pooling on their drive but not since they’ve had the drainage and shingle drive installed (like you said).”
Here's the map, would you be concerned?
