found an old PC what OS for retro gaming
3 Jun 2007
Essex
Hi All.
Dug out an old PC from the in-laws house and thought i would turn it into a retro PC of some kind.
Athlon 4400+ Dual core CPU
3gig of ram
320 HDD
Either a Geforce 760 256mb or i have a 7600 2gig geforce
Just wondering what the best OS would be to use on this machine?
Think I'd be tempted to throw Win7 32bit on there. Unless you want to go seriously retro, in which case bang Windows 2000 SP4 (the mildly less irritating brother of XP) on it :D
Either Windows XP or windows 7, and only 32bit.
Windows XP technically has better compatibility with older games but not by much. Especially for EAX etc sound processing but you don't have a pci/e sound card I assume.
Windows 7 is more usable for normal computing too as it is better at browsing the Web.
Not sure about those graphics cards, I assume you got the vram amounts the wrong way around. The 7600 is not fast enough, the 760 should be perfect for this kind of pc. I have a gtx645 because it does not require any external power and is single slot which is a bonus, but it is plenty powerful for games up to 2011/2.
its actually an Asus 670 2gig
I also have a SB fatality sound card in the machine
Windows 7 came out when that CPU was ending production, so XP would have been used at the time & so would probably pick that. It feels more retro too :D
dual cores are retro? I feel old :o
I would go with XP for that tho. Most games that work on 7 will work on modern pcs. Games for xp and lower will have a higher chance on XP.
