Founders 3080 no display
6 Feb 2019
Hi. My son's gaming monitor froze last night. With a loud beep from the PC. It needed the power button holding down to turn off. Since then there has been no display. The motherboard is stuck on the White GPU light.
I've tried a few things. I'll list below.
Reseated RAM. & Tried 1 stick in each slot.
Reseated GPU
Reset bios . Also removed battery for 5 mins.
Checked all connections.
Tried different display and HDMI cables.
I borrowed my other son's GPU and it booted fine.
While it was on.
I updated GPU drivers
Updated bios
Checked Windows was all up to date.
Refitting the GPU afterwards left the same issue. No picture and white light on mobo.
I put the GPU in my other son's PC and it showed the same fault.
So I'm pretty sure the GPU is faulty. It's a founders edition 3080. Its warranty run out in February so before we have to buy a new one I wondered if anyone may have any other way of recovering it. . I've done the basics but now out of ideas.
This has happened before and just power cycling it got it working again. It has very light use and crashed while just browsing web. It's never been under any heavy load or over temp.
Any advise appreciated. Thanks
Thought as much . I'm a bit out of the loop since the 30 series came out. His PC is 5 - 6 years old now. It's running on a 3700x with a B450 mobo. Is it worth moving up to a 40 / 50 series or just getting another 3080.
Get a repaste done first, then make up your mind ;) At least then you'll know that you've tried everything that you can to bring it back from the dead :)
To be honest. I'm not that confident to strip it. But I'll check on you tube see if there's any guides. Like you say it's worth a go. I've got nothing to loose. Except cost of a tube of paste. .
The founders 4070 is £499. Is that the best bang for buck if all else fails. Just worried rest of system won't keep up.
Ah mate, it can be a bit overwhelming at first, but like you say, get a guide up, pause it every step of the way, and take your time!
A litle tip, get a sheet of paper, do a crude drawing of the card, and push the screws through the location of each corresponding, so you don't have to remember or worry about them rolling further away from wherever you place them during deconstruction :)
Exactly, it's worth a shot for a tube of paste, then if it works great, if not, you can film yourself creatively destroying it, and share the video on this thread :D You can't loose either way ;)
Ah decent, that'll do you well if you were able to pair it with a secondhand 5600X, 5700X, 5800X, 5700X3D :)
You can get a power color reaper 9070 for 489. According to tech power up it’s 21% faster
I only got it to display when I substituted the GPU. It booted fine when I put another GPU in.
Sadly, probably only 2 possibilities.
1) Power issue - cables/psu can't power the card adequately
2) Card is dead and you'll need someone with excellent electronic skills and hardware to take a look - probably not a cost effective option for a 3080
The card showed same fault in a different pc. Mobo lights stop on GPU.
I'll prob have a go at repasting it as I've nowt to loose but from research it sounds like it more than that. And it's never been used hard. I've tried Nvidia and a few places. No one repairs stuff anymore. It's a shame. I got it during the GPU drought. I Managed to get a founders 3080 & 3070 after months on stock alerts. Gutted.
If you can’t fix it you can probably get £100 or so for it even broken, replacing it with a 9070 or if you can stretch a 9070XT as not only are they faster than the 5070 they have more VRAM and also less driver overhead which means when paired with an older chip like a 3700X they would perform far better.
