Four DVB-S2 tuners - needs USALS and Linux support.
27 Jul 2009
Hi,
I am after some PCI-e DVB-S2 tuners for my Linux server, running TVHeadend.
Ultimately, I want three feeds connected to a static minidish, pointing at 28.2e.
The other feed is to be connected to a USALS motorised dish.
What are my options?
I originally looked at one of these:
https://www.tbsdtv.com/products/tbs6...pcie-card.html
However, I have been advised to avoid these as they are a pain to use with Linux.
The only other quad tuner I can find is this:
http://www.digital-devices.eu/shop/...e-set-dd-cine-s2-v7a-und-duoflex-s2-v4a?c=160
otherwise, I might have to look at a couple of these:
https://www.amazon.co.uk/DVBSky-prof.../dp/B0063CDYMK
What do you think I should do?
I'd use whatever works best with Linux. Even if that meant 4x single pci tuners. I used a triple tuner before (1xdvbt2 1xdvbs2 1xdvbc) and it had so many problems as the drivers were terrible at best.
TBS is a good choice if you're willing to pay for it. Drivers are still immature and I had issues getting my working in Linux but all is good now.
For my TV server I got some cheap single PCI DVB-S2 (Technotrend S2-3200) tuners because the TBS ones cost 4-5x as much, they work with Linux (Debian 9) out the box and it has 6 PCI slots anyway so single tuners are no problem. These are classed as budget cut down cards and they have a few occasional locking issues but it's only a minor annoyance. An example of a rock solid card with Linux is the TechniSat SkyStar 2 but they are DVB-S only.
Thanks - it is a shame that the Technotrend are PCI as they are very reasonably priced (I only have a single PCI slot on my server board).
I agree that TBS cards are rather expensive, but I am prepared to go with them as long as they do the job.
What TBS card are you using? Do you struggle with the issues that seem to plague Linux users, following kernel upgrades?
6221. It's a terrestrial card but the process is the same anyway. Could not get the official drivers to work with it. It was like the card wasn't ever supported. They appeared to compile correctly but the modules just wouldn't load. After 3 days I just about gave up but happen to find the updated open source drivers (I had already tried them before but downloaded an older version) which now supported this card and they worked on the first try. I have not attempted a kernal upgrade yet since this was a fresh install not long ago.
