- 25 Nov 2021
- somewhere safe
Hi.
I've got a 5950x and 4 sticks of DDR4 with 3600 xmp frequency. If I install two of them at a time then I can use the xmp profile and memtest86 gives zero errors. If I install all of them then memtest86 gives errors at 3600. But all four at 2666 are fine with memtest86.
I think I've read somewhere than when this happen the culprit is the memory controller on the cpu.
Is that right?
If that's the case then it would be useless to try to change the 4 dimms. Any 4 dimms of any model would give the same problems at 3600 right?
Also, the tests have been conducted with pbo enabled (nothing crazy, just the standard settings). Is pbo causing this? You know, like in certain intel cpus that when you overclocked them you lost the possibility of overclocking the RAM too?
Thanks
Is that right?
Thanks
