I changed my motherboard from an ECS P4M890T-M (crap, that's why I was upgrading it) to a Foxconn P35AX-S (which was cheap, but seemed a damn sight better than my current board). Upon powering the machine built around the board, it didn't POST, it just spammed beeps at me. Quite alarmed I turned the machine off. I did the obvious things, removed most of the non-essential items such as a stick of memory, the optical drive and my hard disk, same spam of beeps POST code again.
I've tried removing pretty much every item from the board except the CPU, and the same problem occurs, I even tried reseating the CPU, three times.
I've rebuilt the machine back up using my old board, and everything's peachy.
Would I be right to assume a RMA is in order?
