FPS Problems?
26 Nov 2008
I'm not 100% sure on this hence the question mark in the forum topic.
Should this set up be running GTA 4 better than an average of 17 - 26fps
AMD Athlon 6000+ @3.11Ghz
Gigabyte MA78G
2gb DDR2 6400 Corsair
XFX Radeon HD4850 512mb GPU Clock @650mhz and memory oc'd to 1100mhz
Windows XPSP3
I'm running everything on low settings @ 1280x800, downloaded GPU-Z and apparently it's never above 3% and the temperatures are very good, haven't seen it go above 45c on GPU-Z.
Is the Athlon bottle necking the graphics card by a lot? Or is GTA4 really as demanding as it seems? The FPS hasn't really changed since the change of graphics card(was using an HIS X1650PRO 512mb)
Edit; it was a clean install of windows after installing the new graphics card.
GTA games have always been sluggish bar the top down ones and run like a pig.
GTA IV unfortunatly is no exeption.
