FPS recording
26 Sep 2015
HI I'm trying to figure out not how to monitor fps in a game
but to actually shoot a film with the fps showing
i try to google this topic but can not find an answer
when i try msi afterburner it shows on screen display but the file size is to big and when i try to render both sony vegas and adobe premier the video is black
then if i try to use fraps to show fps then record with amd gaming evolved the video records in high quality low performance drop and low file size but the fps from fraps is not there
i dont know how to record and show the fps i know that some programs have fps overlay like steam and amd gaming evolved has fps overlay but some games don't work with fps over lay for amd gaming evolved and using fraps to show fps doesn't come out in the videos please help
If you record a lot then might I suggest purchasing Action Mirillis.
Brilliant piece of software available on Steam and uses either the AMD or Nvidia codec to record so performance impact is minimal plus you can record the FPS overlay ingame too :)
thanks for helping me thats pretty cool of u
I would second Mirillis Action but the only downside is you only get free upgrades for the current major version:
Action! license is not time limited.
Action! license also entitles for free updates within purchased product version. In example, when you purchase Action! 1.x.x version then you are entitled to receive free updates for all Action! 1.x.x versions. Upgrade to version 2.x.x or higher will be not free.
